Normal Topic Mouse position for Multiple selection (Read 2160 times)
tusharpateluk
Oct 22nd, 2008 at 9:09am
While handling the Node Modified event, I have observed that If you have multiple items selected mouse position is 0,0 whereas when you select a single node you get the correct mouse position.
I am trying to drag and drop a node on to another node. The node which is dragged will be replaced with the node on which it is dragged. Their are few situations where few nodes are grouped together and when node is being dragged I need to drag the connected node also.
Is their any way to find out If current dragged node is on another node.
Re: Mouse position for Multiple selection
Reply #1 - Oct 22nd, 2008 at 12:10pm
You might use the Rect.IntersectsWith method, for example
if (e.Node.Bound.IntersectsWith(anotherNode.Bounds))
I hope that help,
tusharpateluk
Reply #2 - Oct 22nd, 2008 at 12:29pm
Thanks that works
