Normal Topic Flowlayout and lane nodes (Read 3387 times)
kai-uwe.zoland
Oct 24th, 2008 at 8:23am
I am currently using the FlowLayout class of the WpfDiagram to arrange my diagram using nodes as lanes. I get the first promising results if I have only one lane. Now I want to understand the FlowLayoutTrait 'Lane'. How can I specify for a node before calling the arrange function, which lane it should take? I tried to assign the lane node, that should be used, to the FlowLayoutTrait of the node. But that seems not to work and after the call of the arrange function the value of this trait is changed to an integer. How does the assignment of a node to a lane work? Or how do I specify, in which lane the node should be placed?
And how can I influence the order of the lanes? Do I have to give them different positions? And will the arrange method retain this order of the lanes? Currently I create all nodes and lane nodes at position (0,0).
Kai-Uwe
WWWYIM
Re: Flowlayout and lane nodes
Reply #1 - Oct 24th, 2008 at 9:56am
You should assign someNode.LayoutTraits[Lane] = lane_index where lane_index is the integer lane number. You set some nodes as lanes by setting LayoutTraits[LaneNode] = true for them.
PS. You can see this used in the test application our developers did for you for the Windows Forms version of the control. By the way we have ported this to WPF as well, I can send you the WPF version if you need it.
kai-uwe.zoland
Reply #2 - Oct 24th, 2008 at 10:55am
Where do I get this lane index? Do I set the Lane Trait also for the Lanenode and define it that way? Or is it just the index from the Nodes Collection of the diagram? I also checked the test application, but there I did not find any clue, how this Lane trait works. Or I have some older version of the test application.
  Kai-Uwe
PS.: Can you send me the WPF version of the test application, please. Email is in my profil. Thank you.
WWWYIM
Reply #3 - Oct 24th, 2008 at 12:19pm
The lane index should be a value between 0 and the number of lane nodes - 1. FlowLayout sorts the lanes according to the Y position of the nodes that define them, and the indices correspond to that order. So the lane node at the top has index = 0, the one below it 1, etc.
Reply #4 - Oct 27th, 2008 at 10:45am
Just e-mailed it.
kai-uwe.zoland
Reply #5 - Oct 27th, 2008 at 5:05pm
Thank you, I got your mail and setting the lane node now also works.
Kai-Uwe
WWWYIM
