Normal Topic Problem with TAG (Read 1120 times)
rayan05
Problem with TAG
Oct 27th, 2008 at 1:32pm
I'm using FlowchartX and NetDiagram for Windows & web applications. I'm creating a workflow in FlowchartX and want to open it in NetDiagram via XML saving file. Everything sems working fine, except TAG property.
In FlowchartX the tag value saved properly. But when I tried to open the flowchart in NetDiagram 'Tag' property always returns null. But all other properties returns ok.
Could you help me to solve this ?
Re: Problem with TAG
Reply #1 - Oct 27th, 2008 at 1:59pm
I believe what corresponds to the NetDiagram's Tag property in FlowchartX is called VariantTag. At least that's what get saved under the <Tag> element in XML 8) Both controls should be able to save and load simple value types automatically - such as boolean, integer and string. For other types, handle the SerializeTag and DeserializeTag events.
