Normal Topic Any event before LinkModified (Read 2094 times)
billcch
Oct 28th, 2008 at 2:46am
Is any event I can get before LinkModified? I need to popup a dialog to let user pickup values (based on the mouseover cell) or cancel the event before LinkModified. I cannot use LinkModifying to launch my dialog, because user might drag the cursor over many of cells before the destination cell.
BTW: I am using FlowChart.Net Pro 5.1.1.
Re: Any event before LinkModified
Reply #1 - Oct 28th, 2008 at 7:55am
You could 'cancel' the event by deleting the link: diagram.Links.Remove(e.Link).
billcch
Reply #2 - Oct 28th, 2008 at 3:23pm
Deleting the new link and recreating the original link on LinkModified, yes I am doing so. I was just wonder if there is any event I could use rather than record the original link data - delete the new link - recreate the original link.
Reply #3 - Oct 28th, 2008 at 4:40pm
Sorry, I was thinking about the Created event. You could display the dialog from the LinkModifying handler when Control.MouseButtons indicates that the left button is no longer pressed down - this means Modifying is raised for the last time, and you could set e.Cancel = true from its handler.
billcch
Reply #4 - Oct 29th, 2008 at 8:49pm
Cool, thanks
