Normal Topic Ability to Find Nodes Layout Object (Read 1576 times)
Paul Eden
Nov 1st, 2008 at 2:28pm
Hi
Our diagram is all user input generated, with some nodes being layed out one way, others another way with multiple layouts of the same type (as in there coud be 3 nodes that that all have their own layout). Is there any way I can get the layout object from a node object rather than having to maintain my own list?
Or is it possible to define each layout type I intend to use and then simply change the root node on it and 'arrange' when ever I need to?
Paul
Re: Ability to Find Nodes Layout Object
Reply #1 - Nov 2nd, 2008 at 8:48am
The control does not keep any information regarding what layout has been applied last to a node. You could associate nodes with layout objects using a Hashtable or the Tag property of nodes.
