Normal Topic DiagramLink between a tablecell and table (Read 1593 times)
murat2912
Nov 3rd, 2008 at 3:11pm
Hi everybody...
I want to draw link between a table cell and another table with code.how can i do that?
Re: DiagramLink between a tablecell and table
Reply #1 - Nov 3rd, 2008 at 3:19pm
Try this:
TableNode t1 = diagram.Factory.CreateTableNode(10, 10, 20, 40);
TableNode t2 = diagram.Factory.CreateTableNode(110, 10, 20, 40);
DiagramLink l = diagram.Factory.CreateDiagramLink(t1, 1, t2, -1);
l.Dynamic = true;
-1 designates that the link should not be associated with a row. Dynamic = true lets you verify that indeed the link's origin is connected to a row, and the destination isn't: grab t2 and drag it around t1, and you will notice how the link stays at the second row at t1, while it connects to any point of the t2's outline.
Links are associated with table rows and not with cells, but you could add an anchor point whose Column property is set; this would make the point relative to the cell's bounds.
murat2912
Reply #2 - Nov 3rd, 2008 at 3:59pm
You are perfect.Thanks.
