Normal Topic FlowLayout LaneDistance property (Read 1961 times)
tom_w
Swimlanes made our dreams
come true :-)
Nov 6th, 2008 at 11:25am
Hi
Am I right in saying the FlowLayout.LaneDistance property should insert a blank area between each of the lanes?
I'm having no luck making it do anything, does it only work if I am using nodes for lanes (which I'm not at present)?
Tom
Re: FlowLayout LaneDistance property
Reply #1 - Nov 6th, 2008 at 1:23pm
You are right, it only works when using nodes as lanes. The lanes-grid doesn't yet allow for empty space between lanes.
tom_w
come true :-)
Reply #2 - Nov 6th, 2008 at 1:26pm
Thanks Stoyan.  Do you think I would be better using nodes for lanes - i.e. is that what the flowlayout is primarily designed and tested for at present?
It probably makes sense for me to use a solution as close as possible to the one you guys are doing all the work on?
Reply #3 - Nov 7th, 2008 at 9:15am
There are three methods actually, and they should be equally well tested. Of them, the one that uses the lanes grid doesn't currently allow for distance between lanes. The one you probably don't know of is to just pass an array of rectangles to be used as lanes. Then you could render the lane rectangles yourself using the DrawBackground event. As with lane nodes this will let you use whatever distance between lanes you want, but it's a cleaner solution because you won't have to distinguish between lane and non-lane nodes.
