Normal Topic Limits when moving a node (Read 2235 times)
Stuart
Short, fat and bald, that's
me.
Nov 12th, 2008 at 5:03pm
I have a diagram and often, when moving a node, the cursor changes to tell me I can't drop the node. Obviously there is some kind of boundary.
So, questions:
1. What defines the boundaries of the drag region?
2. Can these boundaries be overridden or, better yet, disabled?
-- &&Stuart
YIM
Re: Limits when moving a node
Reply #1 - Nov 12th, 2008 at 5:55pm
You can make the region bigger using the SetDocSize method. You could also set RestrObjsToDoc = rdNoRestriction to disable the restriction.
Stuart
me.
Reply #2 - Nov 13th, 2008 at 8:21am
Cheers Stoyan
-- &&Stuart
YIM
