Normal Topic uncorrect positions by during drag & drop (Read 1680 times)
SeppiK
Nov 13th, 2008 at 8:57am
before I using drag & drop to fill my diagram with nodes the positions were OK.
Now I´m using drag and drop.
private void diagramView_DragDrop(object sender, DragEventArgs e) {
            if (e.Data.GetDataPresent(DataFormats.StringFormat)) {
                string selected = e.Data.GetData(System.Windows.Forms.DataFormats.StringFormat).ToString();
                coordinates pos = new coordinates(e.X, e.Y);
e.X and e.Y are the position on the screen not in the diargram. From this follows that my nodes were draw on other side of the screen.
How can I get the right coordinates?
Re: uncorrect positions by during drag & drop
Reply #1 - Nov 13th, 2008 at 11:04am
Use Control.PointToClient to get the DiagramView coordinates for the screen point, and then DiagramView.ClientToDoc to get the document coordinates.
SeppiK
Reply #2 - Nov 13th, 2008 at 1:07pm
It works!!
Thanks for your great support every time!
SeppiK
