Normal Topic Link Style change (Read 2597 times)
tusharpateluk
Link Style change
Nov 14th, 2008 at 3:03pm
I am allowing user to change link style and segements. While testing, If their are more segments and if I try to change the same my dragging one of the segement, WPFDiagram does not allow me to change the link position.
I have seen this working on your demo application. I assume their should be some property that allows you to do this. Please help
tusharpateluk
Re: Link Style change
Reply #1 - Nov 14th, 2008 at 3:07pm
Found the problem, It was my mistake. I was handling Link Modifying event.
tusharpateluk
Reply #2 - Nov 14th, 2008 at 3:32pm
Related to the above question. User changes the line style and then clicks copy. When user then clicks paste, The line style is change back to Polyline with 1 segment.
How can I maintain the style and other attributes of the link
Reply #3 - Nov 14th, 2008 at 4:33pm
This worked fine in my test:
DiagramLink link = diagram.Factory.CreateDiagramLink(
	new Point(0, 0), new Point(100, 50));
link.Style = LinkStyle.Cascading;
diagram.Selection.AddItem(link);
diagram.CopyToClipboard(true);
diagram.PasteFromClipboard(new Point(10, 10), true);
Are you sure you aren't changing the style in response to NodePasted or LinkPasted events?
tusharpateluk
Reply #4 - Nov 14th, 2008 at 4:45pm
Thanks, it was in clone method. I found the problem. Thanks again
