Normal Topic PDFexporter (Read 2910 times)
BidMaestro
to learn is to live
PDFexporter
Nov 18th, 2008 at 12:52pm
Good evening all
I am using the pdfexporter to produce some great looking diagrams. I have had a look at the forum and could not find if someone has created some code (vb.net) to imbed a diagram header/title and footer block that prints with the diagram or is there a feature in FlowChart.net that provides this functionality that I have not spotted?
regards
Doug
Re: PDFexporter
Reply #1 - Nov 18th, 2008 at 3:39pm
Good evening,
There's no built-in support, but you might handle the DrawBackground event and draw the header from the handler. DrawBackground should be raised once for each page, and one of its arguments should be the rectangle of the current page, so you might align the header to that rectangle.
BidMaestro
to learn is to live
Re: PDFexporter
Reply #2 - Nov 19th, 2008 at 12:08am
Once again; thank you for the advice which I will try. As an alternative  I am looking at placing a fixed node at the top left of my diagram that contains the information that I want to print (at least on the first page). Finaly for other readers benefit, exporting the diagram to Microsoft's Visio is another option where you can add page background borders/headers/footers)
Regards
Doug
