Normal Topic copy paste/move selected items (Read 7649 times)
toto22
Nov 19th, 2008 at 1:07pm
Is it possible to paste nodes from clipboard at a specific location, the PasteFromClipboard method takes an offset position and not the exact location.
The other option I had was to paste nodes with 0 offset and use the move operation, this works fine when I have a single node copy/paste operation but incase of multiple selections I don’t see any method to move an entire selection. Is it possible to move all the selected items?
Re: copy paste/move selected items
Reply #1 - Nov 19th, 2008 at 1:38pm
It's a bit hackish, but you could do that by simulating users moving the selection to the specified position:
private void MoveSelection(Point newPosition)
	Point oldPosition = diagram.Selection.Bounds.Location;
	InteractionState ist = new InteractionState(diagram.Selection, 8, Action.Modify);
	ist.Start(oldPosition, diagram);
	ist.Update(newPosition, diagram);
	ist.Complete(newPosition, diagram);
toto22
Reply #2 - Nov 19th, 2008 at 5:19pm
thanks for the code.
what about the paste from clipboard, is it possible to paste nodes starting at a specific location?
Reply #3 - Nov 19th, 2008 at 5:44pm
If you know the original position of the items, you could calculate the offset from it to the position where you want the copies to appear and call PasteFromClipboard with that offset. Otherwise, you will have to call that MoveSelection method after PasteFromClipboard.
IgorS
Reply #4 - Nov 25th, 2008 at 1:28pm
Hi, Stoyan.
This code does't seem to be working properly with links. Nodes are moved correctly, but links somehow get absolutely wrong bounds.
Reply #5 - Nov 25th, 2008 at 3:09pm
Perhaps the links are auto-routed? What happens if you set AutoRoute = false for the selected links?
IgorS
Reply #6 - Nov 26th, 2008 at 8:36am
No, they aren't. I solved this by calling
link.ReassignAnchorPoints();
for each pasted link in Selection after moving it.
By the way. Can check if clipbord contains diagram items? I tried Clipboard.GetDataObject().GetData(typeof(Selection)) and Clipboard.GetDataObject().GetData(typeof(DiagramItemCollelection)) but both returned null..
Reply #7 - Nov 26th, 2008 at 9:27am
Use GetDataObject().GetDataPresent(typeof(MemoryStream)).
IgorS
Reply #8 - Nov 27th, 2008 at 3:18pm
Yep, it did Smiley Thanks a lot.
