Normal Topic Upgrade v1.0 to 2.0 sizing issues (Read 3400 times)
njackson60
Nov 19th, 2008 at 6:06pm
We have been using v1.0 Trial of WPFDiagram and have all of the sizes just as we like them (using Millimeter as a MeasureUnit).
We then just recently purchased v2.0 of WPFDiagram and tried to upgrade the existing diagrams to the new version.  What's happening is that the default unit of measurement changed from Millimeter to WpfPoint (I read other forums where that was done intentionally and that's fine), but what happens is when I change the MeasureUnit to Millimeter and then reset all of the sizes back to their original values, nothing happens - the Diagram is still showing large fonts, huge link arrow heads, etc.
Is this a known issue or (more likely) what am I doing wrong?
As always, thanks in advance for your time - you guys have a great product and I love using it!
Neal
Re: Upgrade v1.0 to 2.0 sizing issues
Reply #1 - Nov 20th, 2008 at 8:22am
If you change MeasureUnit back to Millimeter you would have to set the values of all size-related default-value properties in Diagram, e.g. LinkHeadSize, Font.Size, etc. They are listed in the  MeasureUnit topic in the help file. You could multiply each of them by 25.4 / 96 to get default values suitable for millimeters.
njackson60
Reply #2 - Nov 20th, 2008 at 3:45pm
Hi Stoyan,
I did do that - but it looks like the values aren't being accepted for some reason.  No matter what I change the various properties to (LinkHeadShapeSize, etc.) they stay the same size.  I know these values aren't being set in code; I am changing them in the Properties pane in the VS IDE.
Any thoughts?
Reply #3 - Nov 20th, 2008 at 6:08pm
Hi Neal,
The values of these properties are loaded too when calling LoadFromXml. What exactly are you trying to do - set the Diagram properties back to the v1.0 values so that your application continues using millimeters, or scale an old diagram after calling LoadFromXml so that it's measured in WpfPoint?
njackson60
Reply #4 - Nov 20th, 2008 at 6:17pm
Hi Stoyan,
My mistake - I was modifying the properties on a form that was actually not being used.  Once I found the form that IS being used and made the changes, it's all fine.
Sorry to have wasted your time Sad
