Normal Topic Stacking Flow Layout (Read 1439 times)
Paul Eden
Nov 20th, 2008 at 2:09pm
Hi
Is it possible to have a layout that stacks nodes that are at the same level either in a horizonatal or vertical alignment?
Visually it would resemble a vertical tree layout with x layers, which we could use, but the node collapsing (how they are grouped) may not work how we want it to.
Paul
Re: Stacking Flow Layout
Reply #1 - Nov 20th, 2008 at 3:13pm
Could you post here a picture (or email it to support@mindfusion.eu) showing what the layout should look like?
Thank you,
