Normal Topic unable to display full flowchart on diagram view (Read 2313 times)
Ashutosh
Nov 25th, 2008 at 7:00am
I m facing a problem while displaying the flow chart on Diagram View.
There are some ShapeNodes using those i m making Flowchart , i included those on Diagram View.
Also i added Diagram View with Scrollpane so that to get the whole diagram, it is also
showing the Scrollpane but not showing the whole flowchart.
It is succesfully drawing the whole Flowchart but not showing the whole flowchart.
So what should i do to get the whole Flow chart with ScrollPane embedded in it on my frame.
This is how i am adding it my Frame
Diagram diag = new Diagram();
DiagramView diagView = new DiagramView(diag);
JScrollPane scrPane = new JScrollPane(diagView);
new Frame.add(scrPane);
Re: unable to display full flowchart on diagram vi
Reply #1 - Nov 25th, 2008 at 7:21am
This control renders only the part of the chart inside the Bounds rectangle. You could set a larger size using Diagram.setBounds(), or call Diagram.resizeToFitItems() after creating all items.
Ashutosh
Reply #2 - Dec 2nd, 2008 at 6:42am
It works fine. Thanx for your help.
BR
Ashutosh
