Normal Topic Keep ratio (Read 4344 times)
Oskar
I like YaBB 1G - SP1!
Keep ratio
Nov 28th, 2008 at 8:44am
If I set the KeepRatio constraint on a shape node and drag any of the top corners the shape starts moving up and down. Draging the other handles works as expected, it’s only the top left and top right corner that have this behavior.
I’ve tried to work around the problem by setting a MoveDirection constraint but it didn’t help.
Re: Keep ratio
Reply #1 - Nov 28th, 2008 at 3:48pm
Our developer believes it works as expected in all cases, but the constraints are always calculated relatively to the top line. Do you want them applied relatively to the bottom line for the top corners, so the line at the opposite end of a corner always stays in place?
Oskar
Re: Keep ratio
Reply #2 - Dec 1st, 2008 at 9:34am
I would like the top corners to mirror the behavior of the bottom corners. Now the shape node doesn’t have any vertical constraint at all when I drag the top corners. I can movie the whole node up and down.
Re: Keep ratio
Reply #3 - Dec 2nd, 2008 at 7:35am
Ok, our developer will try to implement it later this week.
Re: Keep ratio
Reply #4 - Dec 7th, 2008 at 10:00am
You can find a download link on the private messages page. Indeed it looks better when the opposite corner does not move, we have to admit Smiley
Oskar
Re: Keep ratio
Reply #5 - Dec 8th, 2008 at 8:20am
Perfect.
Oskar
Re: Keep ratio
Reply #6 - Jan 30th, 2009 at 8:43am
It’s not entirely perfect. If you rotate the shape so that the top corners become the bottom corners and then try to drag them, the whole shape fly off screen and sometimes throws exceptions like “A generic error occurred in GDI+” or “Overflow error”.
I’ve not tried this in the 5.2 beta.
Re: Keep ratio
Reply #7 - Feb 1st, 2009 at 2:24pm
This build of the 5.2 beta should fix it:
https://mindfusion.eu/_beta/fcnet52.zip
