Normal Topic tab-key in tables (Read 2769 times)
horjan
tab-key in tables
Nov 28th, 2008 at 9:21am
I would enter the next cell if the user is in inplace-editing-mode and enter the tab-key. Where is the right place to create this behavior?
Re: tab-key in tables
Reply #1 - Nov 28th, 2008 at 10:42am
Handle the EnterInplaceEditMode event to get a reference to the inplace-edit text box. Attach a KeyDown handler to it, and if the pressed key is TAB switch to the next cell using the DiagramView.BeginEdit() method.
horjan
Reply #2 - Dec 2nd, 2008 at 8:47am
Thank you!
I've handled the EnterInplaceEditMode an I've attached a KeyDown handler.
But I can't find a DiagramView.BeginEdit() method, neither in documentation nor in source.
Reply #3 - Dec 2nd, 2008 at 9:35am
If you are using v4.x or older version of the control, there should be something like StartInplaceEdit method in the Cell or Table class.
horjan
Reply #4 - Dec 2nd, 2008 at 9:43am
Thank you - and sorry (I'm a newbie).
Of course you're right. I'm working in an foreign project and the FC-Version is 4.3.1
horjan
Reply #5 - Dec 3rd, 2008 at 8:14am
now I have a table-reference and a cell-reference, I can modify every cell in the table with the BeginInplaceEdit method (I do it in my keyevent). But how can I get out the index of the active cell? I need it to set the right row and column for the next tablecell I would enter if the tab-key pressed.
Horst
Reply #6 - Dec 3rd, 2008 at 11:13am
You receive the column and row indices with the event that starts inplace-editing, e.g. CellDblClicked or CellTextEditing. From then on, you will have to keep these values in members of the form class and update them as necessary when calling BeginInplaceEdit.
