Normal Topic Zoom In/out from a particular Node (Read 4633 times)
unisnk
D'Oh!
Nov 28th, 2008 at 2:28pm
See this Image:
I can zoom the diagram with ZoomIn and ZoomOut methods.
With ZoomIn I obtain this result (I can't see the selection anymore because the chart zooms on top left corner):
I want that Zoom "centers" on selected node, as shown in the following image:
Any hints?
Re: Zoom In/out from a particular Node
Reply #1 - Nov 28th, 2008 at 3:27pm
unisnk
D'Oh!
Reply #2 - Dec 2nd, 2008 at 4:35pm
It helped partially because the function zooms on the middle of the screen, while I need to zoom on a particular selected item (box, arrow or table)
However with your hints, I was able to write a function that does something similar but I've the problem that the object appears on top-left of the screen after Zooming.
This is the code (Delphi):
procedure btnNewZoomInClick;
var
    widthPixels, heightPixels: Single;
    H:HDC;
    centerBeforeZoomX,centerBeforeZoomY,
    centerAfterZoomX,centerAfterZoomY,
    FigureX, FigureY,
    LeftFig,RightFig,TopFig,BottomFig :Integer ;
begin
if fcx.ActiveItemType = aiNone then
  begin
    fcx.ZoomFactor := fcx.ZoomFactor +25;
  end
else
  begin
    H:= GetDC(0);
    widthPixels := GetDeviceCaps(H,HORZRES) ;
    heightPixels := GetDeviceCaps(H,VERTRES) ;
    fcx.ClientPtToDocPt(round(widthPixels/2),round(heightPixels/2),
		  centerBeforeZoomX, centerBeforeZoomY);
    if fcx.ActiveItemType = aiTable then
	fcx.ActiveTable.BoundingRect(LeftFig,TopFig,RightFig,BottomFig);
    if fcx.ActiveItemType = aiArrow then
	fcx.ActiveArrow.BoundingRect(LeftFig,TopFig,RightFig,BottomFig);
    if fcx.ActiveItemType = aiBox then
	fcx.ActiveBox.BoundingRect(LeftFig,TopFig,RightFig,BottomFig);
		  centerAfterZoomX, centerAfterZoomY);
    //I get the "middle" of currently selected object...
    FigureX := (LeftFig+RightFig) div 2;
    FigureY := (TopFig+BottomFig) div 2;
    // old code:
    //    fcx.ScrollX := fcx.ScrollX + centerBeforeZoomX - centerAfterZoomX;
    //    fcx.ScrollY := fcx.ScrollY + centerBeforeZoomY - centerAfterZoomY;
    //I'm trying to scroll the chart: where am I wrong?
    fcx.ScrollX := FigureX - (centerBeforeZoomX- centerAfterZoomX );
    fcx.ScrollY := FigureY - (centerBeforeZoomY- centerAfterZoomY );
  end;
end;
this is what I get:
BEFORE Zooming:
AFTER Zooming:
(It's Wrong because selected box is not on the center of the screen)
Probably I'm wrong on the last two lines of the code, can you help me?
Reply #3 - Dec 3rd, 2008 at 6:24am
You could first set the scroll position so that the active box is centered, and then use the code that preserves the center while zooming:
Private Sub CenterOnActiveBox()
	Dim widthPixels As Single
	Dim heightPixels As Single
	widthPixels = ScaleX(fcx.Width, vbTwips, vbPixels)
	heightPixels = ScaleY(fcx.Height, vbTwips, vbPixels)
	Dim centerBeforeZoomX As Long
	Dim centerBeforeZoomY As Long
	fcx.ClientPtToDocPt widthPixels / 2, heightPixels / 2, _
	Dim dx As Integer, cx As Integer
	cx = (fcx.ActiveBox.Left + fcx.ActiveBox.Right) / 2
	dx = cx - centerBeforeZoomX
	Dim dy As Integer, cy As Integer
	cy = (fcx.ActiveBox.Top + fcx.ActiveBox.bottom) / 2
	dy = cy - centerBeforeZoomY
	fcx.ScrollX = fcx.ScrollX + dx
	fcx.ScrollY = fcx.ScrollY + dy
	fcx.ZoomFactor = fcx.ZoomFactor + 10
	Dim centerAfterZoomX As Long
	Dim centerAfterZoomY As Long
	'this restores the center point
	fcx.ScrollX = fcx.ScrollX + cx - centerAfterZoomX
	fcx.ScrollY = fcx.ScrollY + cy - centerAfterZoomY
End Sub
Note that width/heightPixels in the code above are the width and height of the control, while in your code they refer to the size of the screen.
unisnk
D'Oh!
Reply #4 - Dec 3rd, 2008 at 12:06pm
Well, It works... but because I took the screen size instead of the document size, the box is not perfectly at the center of the screen.
Unfortunately it seems there aren't the ScaleX/ScaleY functions in Delphi and I didn't find an alternative method to get the document size.
Any hints?
Thank you in advance!
Reply #5 - Dec 3rd, 2008 at 12:32pm
The ScaleX/Y calls above just return the pixel width/height of the control as placed on the form. Doesn't the Delphi ActiveX wrapper class add Width / Height properties that return the size in pixels?
unisnk
D'Oh!
Reply #6 - Dec 3rd, 2008 at 1:08pm
it seems that works just calling the following code:
widthPixels := fcx.Width;
heightPixels := fcx.Height;
more simple than I thought... I hope it continues to work well in other tests Grin
Reply #7 - Dec 3rd, 2008 at 1:12pm
