Normal Topic Gridlayout ArrangeDiagram only for visible boxes (Read 3192 times)
unisnk
D'Oh!
Nov 27th, 2008 at 10:09am
hi there,
look at this picture:
All yellow boxes are containers and can contain hundreds of boxes grouped inside.
All "contained" boxes are hidden (set box.visible := false) and the "container" boxes were arranged with gridlayout method.
The method works well but it takes several minutes to execute. I saw in developer guide the "root" property can enable the arrangement only for the specified sub-graph but this can't help because we can have several sub-graphs as you can see on the chart.
Could be possible to add a flag to gridlayout method (and possibly also to spring and tree layouts) that arranges only visible boxes and ignores the invisibles?
Thank you
Re: Gridlayout ArrangeDiagram only for visible box
Reply #1 - Nov 27th, 2008 at 12:25pm
Set IgnoreLayout for each invisible box before applying GridLayout.
unisnk
D'Oh!
Reply #2 - Nov 27th, 2008 at 1:38pm
It seems I "ignored" that property...  Grin
Let's try, I'll inform you if the chart speeds up...
(maybe you have to move this topic to discussion section)
Thank you!
