Normal Topic Interactivity in ImageMap mode (Read 4853 times)
Dec 1st, 2008 at 12:11pm
The ImageMap mode in NetDiagram 2.1 allows drawing nodes and links on the client side, selecting existing items and modifying them. After an item is drawn or resized, the control posts back and raises a server event.
We'll be starting official beta tests in a couple of weeks; if anyone wants to try it now, please download a prerelease build here:
https://mindfusion.eu/_beta/Interactivity.zip
Now the control requires a ScriptManager to exist on the page, as shown in the included sample project.
Please let us know if you have any comments or suggestions.
Re: Interactivity in ImageMap mode
Reply #1 - Dec 2nd, 2008 at 1:21pm
The link above is for the .NET 3.5 build of NetDiagram. Now we have compiled a .NET 2 version:
https://mindfusion.eu/_beta/interactivity_aspnet2.zip
Client-side interactivity relies heavily on the Microsoft Ajax Extensions for ASP.NET library for browser independent DOM access. Since it is a separate download and does not come with the standard ASP.NET 2 runtime, we have moved the client-side interaction functionality to a ControlExtender-derived class called InteractivityExtender. Now the core DiagramView class and the "diagramming.webforms.dll" don't have references to the MS.Ajax assembly "system.web.extensions.dll". To enable client-side interaction, add a reference to InteractivityExtender.dll, add an InteractivityExtender instance to the form and set its TargetControlID to the DiagramView.ID. That's demonstrated in the following sample:
https://mindfusion.eu/_samples/netdiag_Interactivity.zip
Clopy
Reply #2 - Jan 13th, 2009 at 12:13pm
Is there a way to capture the NodeClicked event when using imagemap in interactivity mode?
I'm using it to display a panel with several "tools" (change color, name of node, store some info  about the selected node to the database etc). But in 2.1 with interactivity enabled, the NodeClick event never gets raised.
Thank you
Reply #3 - Jan 13th, 2009 at 12:39pm
It worked fine in my test site. Could you copy your DiagramView initialization code here?
Clopy
Reply #4 - Jan 13th, 2009 at 12:51pm
Ok. I tried also on the beta sample site:
<asp:ScriptManager ID="scriptManager" runat="server">
        </asp:ScriptManager>
        <ndiag:DiagramView ID="diagramView" runat="server"
            ClientSideMode="ImageMap" Height="600px" Width="800px"
            OnNodeCreated="OnNodeCreated" OnNodeClicked="OnNodeClicked">
        </ndiag:DiagramView>
With code behind:
public partial class _Default : System.Web.UI.Page
    protected void Page_Load(object sender, EventArgs e)
internal void OnNodeCreated(object sender, NodeEventArgs e)
ShapeNode shape = e.Node as ShapeNode;
if (shape != null)
shape.Text = "I've been drawn on the client side!";
    internal void OnNodeClicked(object sender, NodeEventArgs e)
        if (shape != null)
            shape.Text = "I've been clicked on the client side!";
but it doesn't trigger the OnNodeClicked event (i've put a debug sign to see if it hits but nothing.
On my normal project (VB.NET) , this is how I create the diagram:
<cc1:InteractivityExtender runat="server" ID="extPT" TargetControlID="ProblemTree" />
                      <ndiag:DiagramView ID="ProblemTree" runat="server" ClientSideMode="ImageMap" />
and this is the code that should be run:
Protected Sub ProblemTree_NodeClicked(ByVal sender As System.Object, ByVal e As MindFusion.Diagramming.NodeEventArgs) Handles ProblemTree.NodeClicked
        pnlDetails.Visible = True
    End Sub
Reply #5 - Jan 13th, 2009 at 12:58pm
oh, great, it works under IE but not Firefox. Our developer will check this.
Clopy
Reply #6 - Jan 13th, 2009 at 1:05pm
true. It works under IE (7 at least).
Thank you for the quick response
Clopy
Reply #7 - Jan 14th, 2009 at 10:47am
Hello again,
one more question.
Is it possible (without messing with the NetDiagram source code) using ImageMap interactivity, to disable interactive creating of nodes and links from users?
(e.g. only let them select and move the nodes)
Thank you,
Mike
Reply #8 - Jan 14th, 2009 at 11:53am
The click event in firefox should be fixed now. Check the private messages page for a download link.
Set DiagramView.Behavior = Modify to enable only selecting and moving nodes.
