Normal Topic ShapeNode tag (Read 1099 times)
tmtton
ShapeNode tag
Dec 3rd, 2008 at 11:15pm
I have user data tagged to a ShapeNode. I need to get this data upon the node selection; but the tag is null in the selectionChanged event handler.
private void diagram_SelectionChanged(object sender, EventArgs e)
    foreach (ShapeNode node in diagram.Selection.Nodes)
        // My tag is always null here?
        if (node.Tag != null)
Re: ShapeNode tag
Reply #1 - Dec 4th, 2008 at 7:56am
Add to the SelectionChanged handler a foreach loop over Diagram.Nodes and print the node tags using Debug.WriteLine(). Are there any tags different from null at all? If the tags are lost after loading a file or copy/paste, check if your tag objects are serializable. Also check if the Tag is not set to null in some other selection related event handler.
