Normal Topic Behavior.Modify (Read 1566 times)
tmtton
Behavior.Modify
Dec 5th, 2008 at 3:33pm
Thanks for your great support.
diagramView1.behavior=Behavior.Modify almost gives us what we need. No new item is created; but the new item (e.g. a ShapeNode) still shows up and then gets removed. How do I prevent the node from even showing up?
Re: Behavior.Modify
Reply #1 - Dec 5th, 2008 at 4:20pm
There is a selection rectangle drawn when Behavior == Modify and you start dragging with the mouse. Is that you take for a new node?
tmtton
Re: Behavior.Modify
Reply #2 - Dec 5th, 2008 at 4:25pm
Yes. No selection rectangle drawn when a user drags with the mouse.
Re: Behavior.Modify
Reply #3 - Dec 5th, 2008 at 5:50pm
You will have to create a custom Behavior class. Derive from ModifyBehavior, override the StartDraw method, and if you detect that the base class returns an InteractionState whose Action is set to Create, return null instead. Assign an instance of your class to the DiagramView.CustomBehavior property.
