Normal Topic Node/Link text modified (Read 1510 times)
marie
Dec 8th, 2008 at 3:58pm
I noticed that the events diagram.NodeModified & diagram.LinkModified are not called when the text of a node or link gets changed. How can I catch that change? Any other modification that I need to know about? (I want to know about any change that needs save)
Thank you.
Marie
« Last Edit: Dec 8th, 2008 at 6:56pm by marie »
Re: Node/Link text modified
Reply #1 - Dec 8th, 2008 at 6:04pm
There are the NodeTextEdited and LinkTextEdited events raised when the user edits the text of an item. You could use the DirtyChanged event to know when the diagram needs saving.
marie
Reply #2 - Dec 8th, 2008 at 6:29pm
Thanks! I will probably use DirtyChanged.
Marie
Edit: DirtyChanged is too sensitive (by example a graph is dirty if selection changed). I will handle it manually Wink
