Normal Topic GetArrowAt at MouseHover ... (Read 1620 times)
bemorem
MacPro Xeon Quad
Dec 9th, 2008 at 7:33am
	  private void tmrHover_Tick(object sender, EventArgs e)
		if (IsInfo == true)
		    tmrHover.Stop();
		    Point clientPoint = fcDepot.PointToClient(MousePosition);
		    PointF docPoint = fcDepot.ClientToDoc(clientPoint);
		    Box bb = fcDepot.GetBoxAt(docPoint);
		    if (bb != null)
			  //box.Text += "beep ";
			  bb.ToolTip = "Node ID:" + bb.Tag;
		    Arrow aa = fcDepot.GetArrowAt(docPoint, 3.0F);
		    if (aa != null)
			  aa.ToolTip = "Link ID:" + aa.Tag;
In box, tooltip is good showing, but In arrow, tooltip is not shown.
What's wrong in above code?
HW: MacPro Xeon Quad/ 4GB RAM&&OS: WinXP sp3 / .NET 3.5&&Dev: VS 2008 C# sp1&&flowchart .Net ver 4.3.x&&
Re: GetArrowAt at MouseHover ...
Reply #1 - Dec 9th, 2008 at 8:58am
The Tooltip control might not refresh itself before the mouse moves. You could set the ToolTip value when the Arrow object is created, that's it if you don't need to change it dynamically.
bemorem
MacPro Xeon Quad
Reply #2 - Dec 10th, 2008 at 12:07am
The tooltip must shown at if(IsInfor==true) only.
so, after ArrowCreate tooltip assign is not good.
Reply #3 - Dec 10th, 2008 at 5:44am
If IsInfo is some global flag for your application specifying whether tooltips should show, you could also set the DiagramView.ShowToolTips property when setting IsInfo.
