Normal Topic Changing a DiagramLink (Read 1478 times)
scot.roach
Dec 10th, 2008 at 11:02am
Newbie to these Controls...
1) How can I, automatically (or with code behind), have the DiagramLink move the Anchor points (Both Origin and Destination) when a ShapeNode (within a DiagramNode) is moved by the user?
2) How to allow user to move a DiagramLink?
I am trying to make a Diagram - something similiar to SQL Server Management Studio - Database Diagrams.
When user moves a Table (ShapeNode) around, the link (ForeignKeys) automatcally changes with it.
Also, user can move just the link around.
Re: Changing a DiagramLink
Reply #1 - Dec 10th, 2008 at 11:12am
1) Set the OriginAnchor and DestinationAnchor properties.
2) Assuming you are using JavaApplet mode, this is enabled by default. To let users drag a link without having to select it first, set ModificationStart = Auto.
For interactivity in ImageMap mode, check this version:
http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=122813350...
