Normal Topic tablenode captions (Read 1067 times)
davidl
tablenode captions
Dec 15th, 2008 at 3:18pm
Is it possible to create a tablenode with a top and bottom caption?
-David
Re: tablenode captions
Reply #1 - Dec 16th, 2008 at 6:32am
If you don't need to enable table scrolling, you could use the last row as a caption. Set the first cell's ColumnSpan = table.ColumnCount and set its Text to whatever you need as a caption. For scrollable tables, you could implement that through custom-drawing.
