Normal Topic How to do drag&drop from a FlowChart Control (Read 2534 times)
debut
Dec 16th, 2008 at 1:03am
How to do drag&drop from a FlowChart Control to the FlowChart Control?
Re: How to do drag&drop from a FlowChart Contr
Reply #1 - Dec 16th, 2008 at 3:10pm
This starts drag-and-drop when Shift is down:
private void diagViewL_MouseMove(object sender, MouseEventArgs e)
	if (e.Button != MouseButtons.Left)
		return;
	if ((Control.ModifierKeys & Keys.Shift) == 0)
		return;
	DiagramNode node = diagL.GetNodeAt(diagViewL.ClientToDoc(e.Location));
	if (diagL.Interaction != null)
		diagL.Interaction.Cancel(diagL);
	if (diagL.Selection.Nodes.Count > 1)
		Diagram diagTemp = new Diagram();
		SelectionCopy copy = diagL.CopySelection(diagL, false, false);
		diagTemp.PasteSelection(diagTemp, copy, null, 0, 0);
		DoDragDrop(diagTemp.SaveToString(), DragDropEffects.Copy);
	else if (node != null && node is ShapeNode)
		DoDragDrop(node as ShapeNode, DragDropEffects.Copy);
private void diagViewR_DragOver(object sender, DragEventArgs e)
	if (e.Data.GetDataPresent("System.String"))
		e.Effect = DragDropEffects.Copy;
	else if (e.Data.GetDataPresent("MindFusion.Diagramming.ShapeNode"))
	else
		e.Effect = DragDropEffects.None;
private void diagViewR_DragDrop(object sender, DragEventArgs e)
		string s = e.Data.GetData("System.String") as string;
		diagTemp.LoadFromString(s);
		SelectionCopy copy = diagTemp.CopySelection(diagTemp, false, false);
		PointF pt = diagViewR.ClientToDoc(Control.MousePosition);
		diagR.PasteSelection(diagR, copy, null, 0, 0);
		if (e.Effect == DragDropEffects.Copy)
			ShapeNode node = e.Data.GetData("MindFusion.Diagramming.ShapeNode") as ShapeNode;
			Point p = diagViewR.PointToClient(new Point(e.X, e.Y));
			PointF pt = diagViewR.ClientToDoc(new Point(p.X, p.Y));
			diagR.Nodes.Add(new ShapeNode(node));
			MessageBox.Show(diagL.Nodes.Count.ToString());
I don't know why our developer added the diagL.Selection.Nodes.Count == 1 case at all; the CopySelection method should work just fine with a single selected node.
debut
Reply #2 - Dec 17th, 2008 at 7:00am
thanks!
1. after drog one node to diagR, the status of mouse is down on diagL, i move mouse on diagL, it begin to select some node, no mousedown or click, why?
2. i must press "shift" and move mouse, only mouse, how to do?
Reply #3 - Dec 17th, 2008 at 8:00am
The NodeStartModifying and SelectionMoving events might be better for this:
private void diagL_NodeStartModifying(object sender, NodeValidationEventArgs e)
	if (e.AdjustmentHandle == AdjustmentHandles.Move)
		e.CancelDrag();
		DoDragDropSelection();
private void diagL_SelectionMoving(object sender, ValidationEventArgs e)
private void DoDragDropSelection()
Additionally, use the forum's Search to find the MoveSelection sample method, which you might use in the Drop handler to move the items just copied to the mouse position.
debut
Reply #4 - Dec 17th, 2008 at 9:36am
it's right work
thank you!
