Normal Topic Link selection in Container (Read 1443 times)
marie
Dec 16th, 2008 at 4:04pm
Once two nodes contained within a container are linked together, I can't select the link anymore. When I click on the link, the container gets selected instead. I tried changing the link's ZOrder, but it didn't help.
You can easily reproduce this by creating a brand new project and setting
diagramView.Behavior = MindFusion.Diagramming.Behavior.LinkContainers;
I believe this is a bug, but maybe some more code is needed? I can send you the code if needed.
Marie
« Last Edit: Dec 16th, 2008 at 6:07pm by marie »
Re: Link selection in Container
Reply #1 - Dec 16th, 2008 at 4:14pm
Set Diagram.HitTestPriority = ZOrder.
marie
Reply #2 - Dec 16th, 2008 at 6:07pm
Thanks!
