Normal Topic To Define Overviewing Area (Read 3579 times)
bemorem
MacPro Xeon Quad
Dec 22nd, 2008 at 8:44am
We need to Define the Overviewing Area .
"Overviewing Area" is a location and size of Area including a center-node(ie. current node) in flowchart.
How can we implement this ?
Thanks & Merry Christmas~!
HW: MacPro Xeon Quad/ 4GB RAM&&OS: WinXP sp3 / .NET 3.5&&Dev: VS 2008 C# sp1&&flowchart .Net ver 4.3.x&&
Re: To Define Overviewing Area
Reply #1 - Dec 22nd, 2008 at 8:55am
Create a RectangleF centered around the current-node Bounds and call DiagramView.ZoomToRect.
bemorem
MacPro Xeon Quad
Reply #2 - Dec 22nd, 2008 at 10:46am
I'm using the overview1 control in another form.
So, I need to synchronizing the overview1 and flowchart.
when click the box, only the neighboring area of box must be shown in overview. --;
Merry X-mas.
Reply #3 - Dec 22nd, 2008 at 1:46pm
This method is available only for DiagramView. The following might work for Overview:
1) set Diagram.Bounds to the rectangle centered around the current node
2) enable Overview.FitAll; this should make the tracking rectangle as big as the overview window
3) save Overview.ScaleFactor into some field
4) disable FitAll and restore the original Diagram.Bounds
5) set Overview.ScaleFactor to the saved value
bemorem
MacPro Xeon Quad
Reply #4 - Dec 23rd, 2008 at 1:56am
	  private void flowChart1_BoxClicked(object sender, BoxMouseArgs e)
		RectangleF rect1 = new RectangleF();
		rect1.Location = e.Box.BoundingRect.Location;
		rect1.Size = e.Box.BoundingRect.Size;
		flowChart1.Bounds = Rectangle.Round(rect1);
		FormClip frmclip = new FormClip();
		frmclip.overview1.Document = flowChart1;
		// fitall
		frmclip.overview1.FitAll = true;
		// save scale factor
		float sf1=frmclip.overview1.ScaleFactor;
		// recover bounds
		frmclip.overview1.FitAll = false;
		frmclip.overview1.Bounds = Rectangle.Round(rect1);
		// recover scale factor
		frmclip.overview1.ScaleFactor = sf1;
		frmclip.Show();
My Code is the Above.
But not work correct.
what's wrong?
result screen shot is here.
http://pic7.ohpy.com/up/elbbs/2008/12/23/161924/1167068144/mid_%BD%C7%C6%D0.png
And My Intend is
http://pic7.ohpy.com/up/elbbs/2008/12/23/161924/1523656014/mid_%B8%F1%C7%A5.gif
Reply #5 - Dec 23rd, 2008 at 6:17am
If you are using FlowChart.NET v4, set flowChart1.DocExtents and not flowChart1.Bounds. The aim is to trick the overview to give you what ScaleFactor would fit the rectangle specified by you, and that can be done by temporarily setting the flowchart's document area to that rectangle and enabling FitAll.
bemorem
MacPro Xeon Quad
Reply #6 - Dec 23rd, 2008 at 7:53am
rect1 = e.Box.BoundingRect;
rect1.Inflate(100, 100);
RectangleF rr = flowChart1.DocExtents;
flowChart1.DocExtents = Rectangle.Round(rect1);
frmclip.Show();
// UnRemarking Here is 2nd After result
//flowChart1.DocExtents = rr;
I tried with docextents.
Result here: "before clicking node"
http://pic7.ohpy.com/up/elbbs/2008/12/23/161924/2109052096/mid_before.gif
"After Clicking Node"
- correct overview, but flowchart's graphic is shifted.
http://pic7.ohpy.com/up/elbbs/2008/12/23/161924/1824715853/mid_after.gif
"After Clicking Node: 2nd case"
- UnCorrect overview, but flowchart's graphic is unchanged.
http://pic7.ohpy.com/up/elbbs/2008/12/23/161924/1380709908/mid_after2.gif
I want Correct Overview and Unchanged Flowchart's Graphic at the same time.
Reply #7 - Dec 23rd, 2008 at 10:54am
Setting DocExtents might also change the ScrollX and ScrollY values, so try saving and restoring them too.
bemorem
MacPro Xeon Quad
Reply #8 - Dec 24th, 2008 at 1:21am
Thanks, It works correctly.
