Normal Topic Create Nodes Dynamically (Read 5618 times)
bfairchild
Jan 2nd, 2009 at 5:53pm
I'm trying to add nodes to the diagram dynamically and am having a few issues. First, when I add nodes like this:
for(int i = 0; i< e.Result.Count; i++)
               ShapeNode node = new ShapeNode(script);
               node.Content = e.Result[i].Name;
               node.Shape = Shapes.Actor;
               node.Width = 100;
               node.Height = 100;
               node.Visible = true;
               node.Name = e.Result[i].Name;
               node.Tag = e.Result[i].Name;
               script.Items.Add(node);
I get the nodes added, but the images on the nodes are not drawn.
Also, in your documentation under Creating and Deleting Items you have this sentence:
There are several shortcut methods provided for creating instances of the predefined node and link types. The methods are members of the diagram's Factory object
But I can't find the "Factory" or the shortcut methods mentioned anywhere in the object tree or the documentation. Where are they?
Help please Smiley.
Re: Create Nodes Dynamically
Reply #1 - Jan 2nd, 2009 at 7:09pm
ShapeNode inherits Content from ContentControl and updates it internally to show its Shape, Text and Image. So you should set these three properties instead of Content. If you need to show anything more elaborate than a label and image inside a node, create a user control class and host its instances inside ControlHost nodes.
bfairchild
Reply #2 - Jan 2nd, 2009 at 7:53pm
That was it. Perfect.
Brian
lpastor
Reply #3 - Jan 10th, 2009 at 5:19pm
HI bfairchild
can you post a correct code ?
I try to create a node dynamically so I need  a good start point . Thanks in advance
Reply #4 - Jan 12th, 2009 at 6:11am
Replace node.Content in that code with node.Text and it should work fine.
bfairchild
Reply #5 - Feb 16th, 2009 at 9:02pm
lpastor,
              node.Width = 100;
              node.Height = 100;
Now, just add the newly created node to a child node collection of another node.
For example, you can add the node to the Nodes property of the diagram:
diagram.Items.Add(node);
hth
