Normal Topic Get Selected item in code (Read 6799 times)
Hai
Jan 7th, 2009 at 10:45am
Hi there
Your control looks very nice and I'm checking if it will swit our needs...
1. I can not find the way of determining the Selected item. ActiveItem return the last added node, not the selected one.
2. Do you plan of connecting this control to WorkflowFoundation and/or XOML output ?
3. How do I delete a node in code (C#)
4. How do I prevent the user from resizing shapes and adding links ? (Behavior.DoNothink was not the solution...)
Many Thanks
Hai
Many Thanks
Re: Get Selected item in code
Reply #1 - Jan 7th, 2009 at 12:03pm
We've changed a lot of things since the first beta, so try this updated version:
https://mindfusion.eu/_beta/DiagramLite.0.9.3.zip
1.
private void OnTestClick(object sender, RoutedEventArgs e)
	foreach (DiagramItem item in diagram.Selection.Items)
		ShapeNode shape = item as ShapeNode;
		if (shape != null)
			shape.Text = "i'm selected";
	ShapeNode active = diagram.ActiveItem as ShapeNode;
	if (active != null)
		active.Text = "the active item";
2. What do you mean by "connecting" it?
3.
diagram.Items.Remove(diagram.Nodes[0]);
4. Could be done by handling the LinkCreating and NodeModifying events
private void OnLinkCreating(object sender, LinkValidationEventArgs e)
	e.CancelDrag();
private void OnNodeModifying(object sender, NodeValidationEventArgs e)
	if (e.AdjustmentHandle != AdjustmentHandles.Move)
		e.CancelDrag();
however NodeModifying does not work correctly at this time. We'll try to fix it later this week.
Hai
Reply #2 - Jan 7th, 2009 at 1:26pm
Hi Stoyo
Thx for the detailed reply… I’m will get into it soon…
Regarding the WF/XOML….
Your control can load and save flow-charts in an XML format…
Workflow foundation is a very good out of the box solution for managing workflows, and is based on XOML files (which are XML files in a specific format)
One of the major problems of the WF is that it works on the server. If your control could give a XOML representation of the flow (into a DOM object or even a string) which can then be sent to the server you will solve a big problem in the industry (Visualize WF on a client-server applications)
Microsoft will love you for that… Wink
Now, I let the user create a flow (this why I use C# in silverlight… I draw the workflow according to the user selections) and then I’ll use a workaround at the moment to send it to the WF but if you will enable this option in the future it will be a great boost for the emerging community of WF & Silverlight users…
TaTa
Hai
Hai
Reply #3 - Jan 7th, 2009 at 2:31pm
Hi Stoyan
All was just as you’ve said Smiley
Please inform me when the next version will be available (NodeModifying thing…)
Many Thanks
Hai
haib@innovashare.com
Reply #4 - Jan 7th, 2009 at 2:43pm
Hi Hai,
That's great Wink We'll check the Workflow Foundation thing after we release v1 of the control.
Hai
Reply #5 - Feb 24th, 2009 at 9:02am
Hi Stoyan
Any news with the WF XOML ?
hai
Reply #6 - Feb 25th, 2009 at 1:59pm
Not yet. Let us finish with the basic features first, before moving to such advanced subjects 8)
Hai
Reply #7 - Feb 26th, 2009 at 2:09pm
Hi Stoyan
I'm fine with that…
So let me ask 2 basic questions… Roll Eyes
1. Do you have an Undo / Redo option ? planned maybe ?
2. Is there a way to position the text of a node under the image instead of the center or should I wait for the 1.0.2 version ?
Many thanks
Hai
Reply #8 - Feb 27th, 2009 at 7:43am
Hi Hai,
1. We have undo/redo in the controls for other platforms, so I suppose we'll port it to Silverlight version as well.
2. Wait for V1.0.2 if you need this for ShapeNodes. Otherwise create a custom control and host it inside ControlNodes.
