Normal Topic Autoroute for new links (Read 2558 times)
mr.brick
Jan 7th, 2009 at 1:54pm
I am experiencing a slightly unexpected behavior when working with autoroute diagram links.
I want to enable autoroute for certain types of diagram links. I want those links to be routed at all times. When such a link is created I set its AutoRoute property to true. I would expect the link to be routed when created, but it is not. The corresponding node must be moved so the autorouting kicks in.
To auto route after a link is created I also tried to call DiagramLink.Route. This method returns false, and routing isn't performed.
The following is the code used to create the autorouted links:
[code]
DiagramLink result = Diagram.Factory.CreateDiagramLink(origin, destination);
result.AllowMoveEnd = false;
result.AllowMoveStart = false;
result.Style = LinkStyle.Bezier;
result.Dynamic = true;
result.HeadShape = ArrowHead.Arrow;
result.SnapToNodeBorder = true;
result.AutoRoute = true;
[/code]
My question is, how to create a diagram link and have it autorouted?
Thanks!
Hynek Cihlar
BoldBrick, s.r.o.
Re: Autoroute for new links
Reply #1 - Jan 7th, 2009 at 2:27pm
Route() returns false if it fails to find a path. If there is some large node in the background, check how the method works with that node's Obstacle property set to false. Additionally, routing might fails if the distance between origin and destination is smaller than RoutingOptions.GridSize, so try setting smaller GridSize or placing the two nodes at a greater distance from each other.
mr.brick
Reply #2 - Jan 7th, 2009 at 2:50pm
I start with an empty diagram and 2 nodes. No obstacle node is in the background.
The links are autorouted fine when moving (dragging) their respective nodes, so I don't think the GridSize is a problem.
Hynek
Reply #3 - Jan 7th, 2009 at 2:55pm
Are both the origin and destination nodes added to the diagram before you call Route? Could you email a small project that reproduces the problem to support@mindfusion.eu?
MUDO
Reply #4 - Feb 18th, 2009 at 11:47pm
Hi!
I have the same problem.
My settings:
Me.Bounds = New System.Drawing.Rectangle(100, 50, 1300, 800)
'Me.Diagram.AllowUnanchoredLinks = False 'mozem pricapit links na shape bez anchorpoints
Me.Diagram.CellFrameStyle = CellFrameStyle.None
Me.Diagram.EnableStyledText = True
Me.Diagram.SnapToAnchor = SnapToAnchor.OnCreateOrModify 'akosi v nich nevidim rozdiel Sad
'Me.Diagram.RoutingOptions.TriggerRerouting = RerouteLinks.WhileCreating
Me.Diagram.ShowAnchors = ShowAnchors.Auto
Me.DiagramView.Behavior = Behavior.DrawLinks 'Defines values that specify how the component responds to actions performed by the user
Me.DiagramView.ModificationStart = ModificationStart.AutoHandles 'Specifies how the user can start modifying an item = aby sa nemusel oznacovat shape pred jeho hybanim
Me.MoOrto.Anchoring = Anchoring.Reassign
Me.MoOrto.BaseLayout = MindFusion.Layout.BaseLayout.Custom
'Me.Diagram.TablesScrollable = True
Me.Diagram.TableBrush = New LinearGradientBrush(Color.White, Color.Green, 45)
Me.Diagram.TablePen = New Pen("0/#FF696969/0/0/0//0/0/10/")
Me.Diagram.TableCustomDraw = CustomDraw.Additional
Me.Diagram.TableStyle = TableStyle.RoundedRectangle
Me.Diagram.TableHandlesStyle = HandlesStyle.EasyMove
Me.Diagram.TableConnectionStyle = TableConnectionStyle.Table
Me.Diagram.TableRowHeight = 5.0!
Me.Diagram.TableColumnWidth = 4.0!
Me.Diagram.LinkBrush = New SolidBrush("#FFFFFFFF")
Me.Diagram.LinkPen = New Pen("0/#FF696969/0/0/0//0/0/10/")
Me.Diagram.LinkCustomDraw = CustomDraw.Additional 'Gets or sets the type of custom drawing performed on this link
Me.Diagram.LinkStyle = LinkStyle.Cascading
Me.Diagram.LinksSnapToBorders = True
Me.Diagram.LinkHeadShape = ArrowHead.None
Me.Diagram.LinkTextStyle = LinkTextStyle.OverLongestSegment
Autorouting is performed after moving shapes Sad
Help?
...MUDO...
Reply #5 - Feb 19th, 2009 at 8:54am
Please save to diagram that has this problem as XML and email it to support@mindfusion.eu.
Reply #6 - Feb 21st, 2009 at 12:48pm
The Diagram.RouteLinks property from the file you emailed us is set to false. The AutoRoute property of links is initialized from it, so set it to true to enable auto-routing of new links.
MUDO
Reply #7 - Feb 21st, 2009 at 1:13pm
Thanx!
...MUDO...
