Normal Topic Draw a image (Read 2978 times)
CanadaProgrammer
Draw a image
Jun 30th, 2011 at 3:40am
I draw a image in a TableNode, but it looks not very clear, lines in the image are little thick. I use same code to draw this image in my sample project, the imgae can be displayed clearly. I changed the property SmoothingMode of DiagramView but I did not make it. Is there anybody can help me ?
Re: Draw a image
Reply #1 - Jun 30th, 2011 at 6:13am
Have you set ImageAlign to a value that does not stretch the image?
CanadaProgrammer
Re: Draw a image
Reply #2 - Jun 30th, 2011 at 11:41pm
I set value Center, Fit to ImageAlign, but the problem stiil is there. I set the image location x = Bounds.X + 2, y = Bounds.Y + 2, but actuall the 2 means 5 pixel, not only 2 pixel. I think that I shall call DeviceToDoc method to convert it but I do not know how. I guess metric of coordinate and size cause this problem.
Re: Draw a image
Reply #3 - Jul 1st, 2011 at 6:26am
How are you setting its location, are you custom-drawing the image?
GDI+ renders images a little bit blurred if they don't start exactly at a device pixel, so our image drawing code aligns images to pixels by calling ClientToDoc(DocToClient(point)); if you are custom-drawing images, you will have to do something similar.
You might also set MeasureUnit to Pixel to avoid conversions, but with that you will have to change the values of all size related properties to ones appropriate for pixels.
CanadaProgrammer
Re: Draw a image
Reply #4 - Jul 1st, 2011 at 10:16pm
Thanks, show my source code to you:
public override void Draw(IGraphics graphics, RenderOptions options)
base.Draw(graphics, options);
this.ImageAlign = MindFusion.Drawing.ImageAlign.Center;
DrawShapeHead(graphics);
protected virtual void DrawShapeHead(IGraphics graphics)
System.Drawing.Image image = System.Drawing.Image.FromFile("SEC.png");
// 2. Show image
Rectangle iconSizePixels = new Rectangle(0, 0, image.Width, image.Height);
RectangleF imageSize = MindFusion.Utilities.DeviceToDoc(graphics, iconSizePixels);
graphics.DrawImage(image, Bounds.X + 2, Bounds.Y + 2, imageSize.Width, imageSize.Height);
Re: Draw a image
Reply #5 - Jul 2nd, 2011 at 8:42am
It should look like this:
graphics.DrawImage(image, AlignToPixel(ControlPoints[0]));
PointF AlignToPixel(PointF point)
	return diagramView.ClientToDoc(diagramView.DocToClient(point));
The DrawImage(image, point) method draws the image in its native size disregarding the measure unit, so you don't have to convert and specify the image size.
CanadaProgrammer
Re: Draw a image
Reply #6 - Jul 3rd, 2011 at 12:45am
It can work, image can be show clearly, thank you. But the location is not correct. I want to show the image at 2 pixel down and 2 pixel right from the left-top corner of TableNode. How to do this ???
Below code can show image at correct position but it is not clear.
PointF p = new Point((int)(Bounds.X + 2), (int)(Bounds.Y + 2));
graphics.DrawImage(image, p);
Below code can show image clearly but the location is not the place I want.
PointF p = this.Parent.PixelToUnit(new Point((int)(Bounds.X + 2), (int)(Bounds.Y + 2)));
Re: Draw a image
Reply #7 - Jul 3rd, 2011 at 8:11am
Try this:
PointF mmPos = Bounds.Location;
Point pxPos = diagramView.DocToClient(mmPos);
pxPos.Offset(2, 2);
mmPos = diagramView.ClientToDoc(pxPos);
graphics.DrawImage(image, mmPos);
or add offset parameters to AlignToPixel to keep it as a utility method:
PointF AlignToPixel(PointF point, int dx, int dy)
	Point pxPos = diagramView.DocToClient(point);
	pxPos.Offset(dx, dy);
	return diagramView.ClientToDoc(pxPos);
CanadaProgrammer
Re: Draw a image
Reply #8 - Jul 3rd, 2011 at 11:43pm
Thanks a lot , it can work fine.
But I have to convert location twice, looks it is not graceful
