Normal Topic How to change mousecursor in diagram (Read 1398 times)
dmz
Jul 7th, 2010 at 8:34am
Hi..
Is it possible to change the default cursor in a diagram? (If I do it in the diagramview nothing changes so I think it must be in the diagram I have to change it) I want to insert new shapenodes by clicking on a button and then clicking somewhere. It works fine just not the cursor-change.
A second question in relation to this:
Can I prevent the user from drawing new nodes in the diagram? I don't want the user to be able to do this by hand.
Re: How to change mousecursor in diagram
Reply #1 - Jul 7th, 2010 at 9:15am
There are several cursor properties, and the diagram switched between them depending on the current context. Try setting the PointerCursor property in this case.
To prevent drawing new nodes, set Behavior = DoNothing, Modify or DrawLinks. DoNothing will not let users draw anything, it will only raise click events. Modify allows selecting and modifying existing items. DrawLinks allows drawing new links but not nodes.
dmz
Reply #2 - Jul 7th, 2010 at 11:52am
Works beatufully.. Smiley Thanks..
