Normal Topic DiagramLink between two specific cells (Read 1680 times)
marie
Jan 7th, 2009 at 4:55pm
I have tableNodes with 2 anchorpoints on each row. Those anchorpoints allow both incoming & outgoing links:
AnchorPoint ptin = new AnchorPoint(50, 50, true, true, Color.Red, 0);
AnchorPoint ptout = new AnchorPoint(50, 50, true, true, Color.Red, 3);
How can I create a link from a specific cell to another ??? ? I can do this using the User Interface, but I don't know how using code.
I used the Entities sample modifiying the above code and adding a button that does:
private void button2_Click(object sender, EventArgs e)
    TableNode node1 = null, node2 = null;
    foreach (DiagramNode node in this.diagram.Nodes)
        if (node is TableNode)
            if (node1 == null)
                node1 = (TableNode)node;
            else if (node2 == null)
                node2 = (TableNode)node;
                break;
    if (node1 != null && node2 != null)
        // Create link between 2 specific cells
        this.diagram.Factory.CreateDiagramLink(node1, 0, node2, 0);
By default, it uses the column 2 for node1 and column 1 for node2. I would like to specifiy which columns, by example from column 2 to column 2.
Marie
« Last Edit: Jan 8th, 2009 at 5:28pm by marie »
Re: DiagramLink between two specific cells
Reply #1 - Jan 7th, 2009 at 8:19pm
Set the link's OriginAnchor and DestinationAnchor properties after creating it.
marie
Reply #2 - Jan 8th, 2009 at 5:28pm
Thanks again Stoyo! You're a big help Smiley.
