Normal Topic How can I secah node? (Read 3389 times)
lpastor
Jan 11th, 2009 at 6:54pm
I have more than one node in diagram .
I whant to remove all node except one.
1 case is to remove all except one that I click on
2 case is to remove any node with name "123"
also I have a problem with remove Item or Remove node ... don't work
Re: How can I secah node?
Reply #1 - Jan 12th, 2009 at 6:06am
Remove should work in this version:
https://mindfusion.eu/_beta/DiagramLite.0.9.3.zip
You cannot remove items from a collection while iterating over the collection, so you will have to use a second collection and loop:
DiagramNodeCollection toRemove = new DiagramNodeCollection();
foreach (ShapeNode node is diagram.Nodes)
	if (!node.Selected)
		toRemove.Add(node);
	if (node.Text == "123")
		toRemove.Add(node);
foreach (DiagramNode node is toRemove)
	diagram.Items.Remove(node);
