Normal Topic efficiently creating diagramlinks (Read 2511 times)
deanhully
Jan 14th, 2009 at 12:49am
Stoyo,
I am creating diagrams with many nodes and diagramLinks. By far the slowest part of the process is the constructor for the diagramLink objects. I am using the ctor:
new diagramlink(diagram, origin, dest)
it is the fastest method I have found. Any suggestions for speeding up this?
Dean
Re: efficiently creating diagramlinks
Reply #1 - Jan 14th, 2009 at 5:46am
If you are using link auto-routing, you should create the links after all nodes have been added. Otherwise, each added node might lead to the re-routing of several links.
deanhully
Reply #2 - Jan 14th, 2009 at 2:02pm
No, not using auto routing. It's a pretty simple diagram just lots of nodes (~1k) and links (~20k).
At this point I am creating all the nodes first and then adding the diagram links.
Dean
Reply #3 - Jan 14th, 2009 at 2:10pm
Oh. Try that with Diagram.ValidityChecks = false.
deanhully
Reply #4 - Jan 14th, 2009 at 2:16pm
37% faster - thanks, Stoyo!
Any other magic up your sleeves?
Dean
Reply #5 - Jan 14th, 2009 at 2:32pm
Smiley Another thing you might try: create a Diagram object without displaying it inside any DiagramView, populate it, and assign it to DiagramView.Diagram only after all items have been created. This will avoid many calls to the diagramview's repaint handler.
