Hot Topic (More than 10 Replies) Diagram background image (Read 5250 times)
vtortola
Jan 14th, 2009 at 1:37pm
Hi again,
I'm setting up a diagram background image at runtime, but the image used to be hidden til I resize the diagram. I said "used to" because sometimes appears from the beginning... i don't know why... When doesn't appear, I move one of the shapes out of the design surface and then appears.
How could I refresh the diagram ?
Cheers.
Re: Diagram background image
Reply #1 - Jan 14th, 2009 at 2:20pm
Does it appear if you call Diagram.InvalidateVisual() after setting the image?
vtortola
Reply #2 - Jan 14th, 2009 at 4:12pm
Nope   Tongue
Reply #3 - Jan 19th, 2009 at 10:34am
That's a bug; the property setter does not invalidate the background layer correctly. We'll fix it in the v2.1 release. As a workaround, after setting BackgroundImage you could set some other property that invalidates the background , say GridColor.
vtortola
Reply #4 - Jan 21st, 2009 at 1:57pm
Thanks, but doesn't work neither  Tongue
Cheers.
Reply #5 - Jan 21st, 2009 at 2:49pm
Have you tried it with version 2.1?
vtortola
Reply #6 - Jan 21st, 2009 at 3:25pm
No sorry, we can't afford use beta versions in our production software.
We'll wait to the next release, is not a critical issue Wink
Cheers.
Reply #7 - Jan 21st, 2009 at 3:28pm
vtortola
Reply #8 - Jan 21st, 2009 at 6:44pm
We're registered customers and we didn't receive nothing about a new version ???
We received a CD by postal service but doesn't appears which version is? Do we have to download it from anywhere ?
The name of my company appears in my email address Tongue
Cheers.
Reply #9 - Jan 21st, 2009 at 7:11pm
jacques@your domain should have received a download link by email earlier today. Now you can find it on the PM page.
vtortola
Reply #10 - Jan 21st, 2009 at 7:29pm
thanks .
