Hot Topic (More than 10 Replies) Missing DiagramItems after succesful pasteSelectio (Read 4483 times)
SeppiK
Jan 14th, 2009 at 2:38pm
I use copy- and pasteSelection() to implement my own copy and paste concept.
After using this, the DiagramView.Diagram.Items holds the new objects, but they arenīt draw into the diagram.
To use DiagramView.update() and DiagramView.refresh() are unsuccessful.
Re: Missing DiagramItems after succesful pasteSele
Reply #1 - Jan 14th, 2009 at 2:48pm
Do you mean those methods from the Clipboard sample? Check if the items coordinates are within the Diagram.Bounds.
SeppiK
Reply #2 - Jan 14th, 2009 at 3:03pm
the coordinate are present.
Here is some code of my application:
CopySelection
SelectionCopy test = new SelectionCopy(new DiagramItemCollection(), new DiagramItemCollection(), new GroupCollection());
test = this.diagram.CopySelection(this.diagram, false, false);
PasteSelection
this.diagram.PasteSelection(this.diagram, test, null, this.x, this.y);
Reply #3 - Jan 15th, 2009 at 9:09am
This works fine:
private void button2_Click(object sender, EventArgs e)
	SelectionCopy test = diagram.CopySelection(diagram, false, false);
	diagram.PasteSelection(diagram, test, null, 10, 10);
If your x and y values are 0, the cloned items will overlap the original ones and you might not be able to see them.
SeppiK
Reply #4 - Jan 15th, 2009 at 10:15am
It works,
but now I've the problem that some DiagramLinks switch to other anchor after moving a node.
I use the TableNode element with anchor pattern like the ERM Diagram in your demo.
In my application Iīve one input anchor and multiple output anchor per TableNode. Itīs a tree structur.
When I move the parent node after copy and paste one link switch from output to input anchor.
Before moving the parent nodes IncomingLinks list are empty.
Thx for support
Reply #5 - Jan 15th, 2009 at 3:09pm
I can imagine the link doing that if its Dynamic property is enabled, and if your anchor points allow both incoming and outgoing links. If that's not the case, please save your diagram into an xml file and email it to support@mindfusion.eu.
SeppiK
Reply #6 - Jan 16th, 2009 at 9:54am
I `ve send you my diagram per XML.
Before and After Moving.
greetz SeppiK
Reply #7 - Jan 16th, 2009 at 1:52pm
What Flowchart.NET version are you using?
SeppiK
Reply #8 - Jan 16th, 2009 at 3:52pm
Hey,
I am sorry, but I canīt check it before monday.
Have a good weekend.
SeppiK
Reply #9 - Jan 21st, 2009 at 8:04am
sorry for my late answer.
We use version 5.0.2
Reply #10 - Jan 21st, 2009 at 7:06pm
Try that with the updated 5.0.2 assemblies from the private messages page. Let me know if you still have any problems.
