Normal Topic overlapping links (Read 2462 times)
BidMaestro
to learn is to live
overlapping links
Jan 15th, 2009 at 7:19am
Hi there
As an example; I have two nodes with two links between them that convey different information in their text fields. The two links overlap when created under program control, which makes the text unreadable.
Is there a method to keep the links separated and not overlapping.
regards
Doug Livingstone
Re: overlapping links
Reply #1 - Jan 15th, 2009 at 9:27am
Hi Doug,
Check if OrthogonalLayout.Arrange() works for you. Note that the class is called OrthogonalRouter if you are using v5.2 pre-release build.
BidMaestro
to learn is to live
Reply #2 - Jan 15th, 2009 at 10:41am
Firstly; a happy New Year to you. Orthogonal works but does not provide the overall appearance that I need. I may have to use the bezier and manually separate the links to enable the text to be seen.
I also use LinkTextStyle.Rotate for the text to follow the link line. I just need the two links to somehow repel each other halfway between the nodes so that the links both arc between the nodes (not straight lines) to ensure the text is readable.   I hope this makes sense.
Doug
Doug
BidMaestro
to learn is to live
Reply #3 - Jan 15th, 2009 at 11:32am
After doing some reading of the develoeprs guide; is it possibe via program control to manipulate the DrawAdjustmentHandles for the links between two nodes to spread the links apart?
Doug
Reply #4 - Jan 15th, 2009 at 2:27pm
Hi Doug,
Check the code from this post:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=122711142...
BidMaestro
to learn is to live
Reply #5 - Jan 15th, 2009 at 2:34pm
Thanks, I will try this tomorrow
Have a good day.
Doug
