Normal Topic Link with CustomDraw=Full, cascading LinkStyle (Read 3044 times)
MUDO
Jan 15th, 2009 at 6:41pm
Hi.
I want to do this:
I have my own starting & ending points of links. It is M:N relationship betweenn two tables. I want to use cascade & polyline (a oblique line) style of links.
Since I want to draw starting & ending points ONLY horizontaly or vertically I need additional space around shape --> on a picture is this area as RED. In this area I want to have all segments of links in horizontal or vertical orientation.
http://i40.tinypic.com/2uh7701.jpg
How to do this?
1) I was thinking about creating hundreds of anchorpoints around shape. There is a problem with coordinates of these points because they are set relative to shape (in percent).
2) Another way is to play with anchorpoints of cascade links. But x&y coordinates are readonly (am I right?). I have a link with CustomDraw=Full. In DrawLink event I draw my own line. After that original anchorpoints are still visible and area bounded by original link is handling link selection. Is it possible to establish my line as a new link? So when I click on a line it has the same effect like when I clicked on original link? Is it possible to arrange anchorpoints (x & y coordinates)?
So. I think Im not first who want to do something similar.
Can you give me some suggestion what is possible, good and effective?
Thanx!
...MUDO..
Re: Link with CustomDraw=Full, cascading LinkStyle
Reply #1 - Jan 15th, 2009 at 7:06pm
You want the links not to bend inside the red area?
MUDO
Reply #2 - Jan 15th, 2009 at 7:20pm
Hi!
Yes.
Im just testing something.
This is my solution:
link.SnapToNodeBorder = True
link.HeadShape = MindFusion.Diagramming.ArrowHead.None
link.Style = MindFusion.Diagramming.LinkStyle.Cascading
link.AutoRoute = True
Diagram.AllowUnanchoredLinks = True
link.CustomDraw = MindFusion.Diagramming.CustomDraw.Additional
Then I handle Diagram_DrawLink where I draw starting & ending points of links.
This is working now as I want. And that is working when style of links is polyline as well! First segments of links are still horizontal or vertical. OK!
Question is: for what is link.CascadeOrientation? I dont see any changes!
...MUDO...
Reply #3 - Jan 16th, 2009 at 9:31am
It seems link.AutoRoute overrides link.CascadeOrientation, using the StartOrientation in RoutingOptions instead.
MUDO
Reply #4 - Jan 16th, 2009 at 10:36am
No. It doesnt work. It seems like AutoRoute overrides link.CascadeOrientation and all RoutingOptions Sad
Any new idea?
All what I want to do is force first segment to be in vertical or horizontal way.
...MUDO...
Reply #5 - Jan 18th, 2009 at 10:50am
The link routing function finds a route between the current end points of the link, without moving them to ensure RoutingOptions.Start/EndOrientation are appropriate for the node side to which a link is connected - is that the problem? So if you need a link start segment to be vertical, you'd have to align the link's ControlPoints[0] to the top or bottom of the node before routing.
