Normal Topic Pretty happy with Wpf Diagram (Read 2953 times)
vtortola
Jan 16th, 2009 at 3:23pm
We're pretty happy with the component (and with the support forums of course Smiley ).
There are some things I'm missing:
  • More examples with source code (better than docs the most of the times).
  • More dependency properties, for use data binding, animations in the shapes and do the most with XAML.
  • While dependency properties and WPF data binding is comming... a better way to data bind rather than use the "Tag" property.
  • XML classes documentation for Intellisense (better than docs, if the object model is good)
Cheers.
Re: Pretty happy with Wpf Diagram
Reply #1 - Jan 16th, 2009 at 4:52pm
Thank you for your feedback Smiley Regarding Intellisense, you can find the XML files in the same folder where the control's assemblies are installed.
vtortola
Reply #2 - Jan 22nd, 2009 at 4:48pm
oh great.
cheers.
