Normal Topic Links disappear in selected container? (Read 2956 times)
leendert.versluijs
Jan 27th, 2009 at 9:41am
When i draw a link between two nodes which are placed in a containernode that link disappears when the container becomes selected. The nodes are still visible. When a link goes to another node outside the container the part of the link outside the container is still visible.
Have i forgotten some setting or is this a problem?
Can you please help me with this issue.
Kind regards,
Leendert
leendert.versluijs
Re: Links disappear in selected container?
Reply #1 - Jan 27th, 2009 at 1:54pm
Hi Stoyan,
Additional information on this issue that might help you find a solution for me.
If not the container but a node in the container is selected only the incoming and outgoing links for the selected object are visible with the container bounds. Other links within the bounds are not shown. Links or parts of links outside the bound of the container are visible.
The containers are nested and the largest container which contains other containers. The bounds of this largest container determine whether a link or part of is visible regards whether the large container or child is selected.
Hope this help with finding the issue.
Kind regards,
Leendert
Reply #2 - Jan 28th, 2009 at 10:49am
Could you try that with this version?
https://mindfusion.eu/_beta/wpfdiag211.zip
leendert.versluijs
Reply #3 - Jan 28th, 2009 at 2:21pm
Hello Stoyan,
This version does not fix the problem.
Situation is as follows
Diagram Canvas
     Node1  (link A to Node2)
     Container level 1
             Container level 2
                     Node2 (link A to Node1, Link B to Node3)
                     Node3 (Link B to Node2)
Click on diagram canvas --> all show
Select Container 1 --> links and part of links within bounds of container 2 disappear
Select Container 2 --> same as container 1
Select Node2 --> link A & B are both shown since they are connected to Node2
Select Node3 --> only Link B shows, link A disappears.
There is a difference compared to 2.10 where links were also not shown on Container 1
Kind regards,
Leendert
Reply #4 - Feb 3rd, 2009 at 10:36am
Hi Leendert,
This updated version should work better:
leendert.versluijs
Reply #5 - Feb 4th, 2009 at 11:07am
Hi Stoyan,
Thanks, the links are now all shown correctly.
