Hot Topic (More than 10 Replies) Shape decoration misplaced in PDF (Read 5000 times)
leendert.versluijs
Jan 27th, 2009 at 9:50am
When i export my diagram to PDF the decorations of a shape are not placed correctly.
The shapes are placed in a nested container (two levels of conainers) and the offset of the decoration seem to be related to the containers instead of the shape.
Is there a solution for this problem?
Kind regards,
Leendert
Re: Shape decoration misplaced in PDF
Reply #1 - Jan 27th, 2009 at 10:26am
By decorations do you mean decoration lines in the Shape definition?
leendert.versluijs
Reply #2 - Jan 27th, 2009 at 10:45am
Hi Stoyan,
Indeed the decoration elements of the shape.
For example my main decoration is a carshape with two weels (circles) as decoration.
Kind regards,
Leendert
Reply #3 - Jan 27th, 2009 at 11:33am
This worked fine in my test app. Are you using Wpfdiagram version 2.1?
leendert.versluijs
Reply #4 - Jan 27th, 2009 at 12:00pm
We're using version 2.1.
Leendert
Reply #5 - Jan 27th, 2009 at 12:09pm
Could you copy your shape definition and pdf export code here?
leendert.versluijs
Reply #6 - Jan 27th, 2009 at 1:08pm
Hi Stoyan,
Here is the request code. Hope this helps.
SHAPE Definition:
       private static Shape shape = new Shape(
           new ElementTemplate[]
               new LineTemplate(98, 0, 100, 0),
               new LineTemplate(100, 0, 100, 40),
               new LineTemplate(100, 40, 100, 45),
               new LineTemplate(100, 45, 70, 45),
               new LineTemplate(70, 45, 29, 45),
               new LineTemplate(29, 45, 30, 42),
               new LineTemplate(30, 42, 33, 42),
               new LineTemplate(33, 42, 33, 34),
               new LineTemplate(33, 34, 51, 30),
               new LineTemplate(51, 30, 55, 20),
               new LineTemplate(55, 20, 60, 20),
               new LineTemplate(60, 20, 60, 30),
               new LineTemplate(60, 30, 70, 30),
               new LineTemplate(70, 30, 70, 20),
               new LineTemplate(70, 20, 75, 20),
               new LineTemplate(75, 20, 75, 30),
               new LineTemplate(75, 30, 95, 30),
               new LineTemplate(95, 30, 95, 20),
               new LineTemplate(95, 20, 56, 20),
               new LineTemplate(56, 20, 59, 15),
               new LineTemplate(59, 15, 98, 15),
               new LineTemplate(98, 15, 98, 0)
               new ArcTemplate(80, 36, 12, 14, 0, 360, Colors.Black, DashStyles.Solid, 6),
               new ArcTemplate(40, 36, 12, 14, 0, 360, Colors.Black, DashStyles.Solid, 6)
               new LineTemplate(0, 60, 100, 60),
               new LineTemplate(100, 60, 100, 80),
               new LineTemplate(100, 80, 0, 80),
               new LineTemplate(0, 80, 0, 60)
           FillRule.EvenOdd, typeof(CISSSANode).Name);
       private static Brush brush = Brushes.Olive;
       private static Pen pen = new Pen(Brushes.DarkOliveGreen, 2);
       private static Brush textBrush = Brushes.Black;
PDF Export code:
       private void Pdf_Executed(object sender, ExecutedRoutedEventArgs e)
           try
               SaveFileDialog dialog = new SaveFileDialog();
               dialog.FileName = Header.ToString();
               dialog.DefaultExt = ".pdf";
               dialog.Filter = "PDF documents (.pdf)|*.pdf";
               bool? result = dialog.ShowDialog();
               if (result == true)
                   myDiagram.ResizeToFitItems(0);
                   PdfExporter exporter = new PdfExporter();
                   exporter.PageSize = MindFusion.Pdf.PageSize.A0;
                   exporter.PageOrientation = MindFusion.Pdf.PageOrientation.Landscape;
                   exporter.AutoScale = AutoScale.FitToPage;
                   exporter.AutoOrientation = true;
                   exporter.Export(myDiagram, dialog.FileName);
           catch (Exception ex)
               MessageBox.Show("Error exporting diagram. Details: " + ex.Message, "Error");
Reply #7 - Jan 28th, 2009 at 3:42pm
That's a very nice shape 8) The tyres get misplaced indeed, even without containers. Our developer will debug this tomorrow.
Reply #8 - Feb 10th, 2009 at 2:33pm
This version should fix the displacement:
https://mindfusion.eu/_beta/wpfdiag211.zip
leendert.versluijs
Reply #9 - Feb 16th, 2009 at 11:08am
Hello Stoyo,
What happened to the download ???
How can we obtain the released 2.1.1 version? We have a license including source code. The license is however managed by our it department and it helps if i can tell them how the procedure for getting the update is.
Kind regards,
LEendert
Reply #10 - Feb 16th, 2009 at 11:43am
We have removed the 2.1.1 beta files now that we have released the official version. We email upgrade links to the addresses entered on the purchase form. You might send me a private message with your company name and I will add you to our mailing list.
