Normal Topic XML binding (Read 1378 times)
anurodhora
XML binding
Feb 15th, 2009 at 10:16am
Could you please tell me how can we achieve following scenario with wpfDiagram :
We will be having an XML file which will be given as source to the wpfDiagram and whenever there is an update to that xml the graph should accordingly adjust/repaint itself without the need of writing any line of code. Provided that the xml will also be having positional information.
So, how can we achieve above mentioned scenario and can you please give us the xml format and the binding code.
Anurodh
Re: XML binding
Reply #1 - Feb 16th, 2009 at 9:15am
Built-in databinding will be available in the next release, in a few weeks time.
