Normal Topic Delete node without removing links (Read 1445 times)
kc13
Jan 27th, 2009 at 1:42pm
When I remove a node using: diagram.Nodes.Remove(nod) it also removes the links attached to that node.  I have diagram.AllowUnconnectedLinks = True.
How do I prevent the links from being removed since apparently the linkdeleting events do not fire when removing programmatically?
Re: Delete node without removing links
Reply #1 - Jan 27th, 2009 at 3:42pm
Try detaching the links from the node first, by setting their Origin and Destination to a new DummyNode instance.
