Normal Topic Version 2.1.1 beta (Read 3377 times)
Version 2.1.1 beta
Jan 28th, 2009 at 11:17am
https://mindfusion.eu/_beta/wpfdiag211.zip
~ This version implements the most requested feature so far, the DiagramView control, which can be used to implement MDI interfaces where several views show different parts of a Diagram. In Xaml one of the views can be set as container of the diagram as shown below:
<d:DiagramView x:Name="dv1" Grid.Row="1" Grid.ColumnSpan="2" Margin="0,0.223,0,0">
	<d:Diagram x:Name="d" Bounds='0, 0, 100, 100'></d:Diagram>
</d:DiagramView>
and other views can be bound to the same diagram either by programmatically setting their Diagram property, or by using the WPF binding syntax in Xaml for the Diagram property.
~ TreeLayout has been extended to arrange binary trees as shown below:
To enable this, set TreeLayout.Type = TreeLayoutType.HorizontalVertical.
~ TreeLayout can create MS-Office like organization charts. To set some nodes as assistants, set
node.LayoutTraits[MindFusion.Layout.TreeLayoutTraits.Assistant] = true;
and before calling TreeLayout.Arrange:
treeLayout.Enableassistants = true;
~ The AutoUpdateSize property is now called SizeSyncMode and its values can be set to the following:
- Arrange: Resizing the node calls Arrange on the hosted element.
- SetSize: Resizing the node sets the hosted element's Width and Height properties.
- Measure: The node is resized automatically to match the element's DesiredSize.
Even if you don't try any new features, it still helps us a lot to check if your existing applications run fine with the new version.
Many thanks to anyone who tries this beta version!
Paul Eden
Re: Version 2.1.1 beta
Reply #1 - Jan 30th, 2009 at 11:17am
I notice that the TreeLayoutDirection enum has been renamed to TreeLayoutDirections - not a killer, granted, but it is akward (I presume I've not missed a post saying this was changed?).
Paul
Reply #2 - Jan 30th, 2009 at 11:31am
Now it's a flag enum, the directions can be combined for the HorizontalVertical layout, and Microsoft recommend flag enum names to be in plural. We'll upload updated docs next week.
Paul Eden
Reply #3 - Jan 30th, 2009 at 11:44am
Just tried the SizeSyncMode - looking good Smiley
We apreciate you and your teams efforts, and thank you all for it.
I also found today the cause of my issue with the help file released a couple of weeks ago - Vista had marked it as "coming from a different computer" and had blocked it (the fact that the file + it's content are local yet it still blocked it is beyond me..) - clicking an "unblock" button on the file properties tab cleared the problem.
Paul
Reply #4 - Jan 30th, 2009 at 11:58am
great 8)
Reply #5 - Feb 10th, 2009 at 2:38pm
Last beta build:
We are releasing version 2.1.1 on Friday if no further bugs come up by then.
