Normal Topic Arrange and containers (Read 1292 times)
leendert.versluijs
Jan 28th, 2009 at 3:38pm
Which layout should be used in the following scenario:
DiagramElements:
Containers on diagram
Containers in containers
Nodes in containers
Nodes on diagram
Links between nodes
Rules:
Containers are resized to contain nodes
Nodes on diagram are not placed in container
Nodes are kept within same container
Kan you please tell me which layout i should use for this scenario?
Kind regards,
Leendert
Re: Arrange and containers
Reply #1 - Jan 28th, 2009 at 3:55pm
None of the layout classes will do that automatically. You can call Arrange recursively on the items in containers using the Arrange(DiagramItemCollection) method, starting from the bottommost nodes and the final Arrange being called on the topmost containers and nodes. Check this thread for some hints:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=120224899...
