Normal Topic Event for container resized (when a node is moved) (Read 4379 times)
marie
Jan 29th, 2009 at 6:57pm
Hi!
When a node is moved within a container, the container gets resized if necessary. I need to know how to catch this event. I tried using NodeModified on the container but it is not called.
NodeModified gets called for the node, so I can catch that and then if it has a container I can get its new size. However, it seems that the container's size has not been updated yet.
How can I get that?
Thank you,
Marie
« Last Edit: Feb 17th, 2009 at 8:41pm by marie »
Re: Event for container resized (when a node is mo
Reply #1 - Jan 30th, 2009 at 4:54pm
Hi Marie,
Try this build of the 5.2 beta:
https://mindfusion.eu/_beta/fcnet52.zip
NodeModified is still raised only for the child node, but after updating container.Bounds.
marie
Reply #2 - Feb 3rd, 2009 at 8:32pm
Hi Stoyan!
Thanks a lot Smiley
Could you do the same for this.diagram.ContainerChildAdded and this.diagram.ContainerChildRemoved (update the container's size before calling those)?
Thanks again,
Marie
marie
Reply #3 - Feb 9th, 2009 at 1:53pm
Did you forget about this post?
Marie
Reply #4 - Feb 9th, 2009 at 2:03pm
Nope - that's the first thing we'll do after the v5.2 release 8)
marie
Reply #5 - Feb 9th, 2009 at 2:36pm
Thanks Smiley
Marie
Reply #6 - Feb 16th, 2009 at 9:53am
Hi Marie,
The version from the PM page implements that.
marie
Reply #7 - Feb 17th, 2009 at 8:26pm
Hi Stoyan,
Thanks a lot! It works perfectly.
The version you sent me, is it tagged for my company? Does it include everything from the previous 5.2 release? Can I use it safely (distribute it to clients)?
Marie
Reply #8 - Feb 17th, 2009 at 8:38pm
Hi Marie,
Yes, it includes everything from v5.2 and should be stable enough ...
marie
Reply #9 - Feb 17th, 2009 at 8:40pm
Perfect  Cheesy
