Normal Topic arrange diagram (Read 2276 times)
nick00
arrange diagram
Feb 3rd, 2009 at 2:38pm
hi,
I am creating the node and simulteniously arraging the node horizontal manner, and then linking them according the relation in DB.
I set CascadeOrientation= vertical
linkstyle= cascade
lsegments= 3
but still my links appears
horizatally, I want the link attaches the nodes from top of the node.
Re: arrange diagram
Reply #1 - Feb 3rd, 2009 at 3:07pm
Try it in this order:
link.Style = LinkStyle.Cascading;
link.SegmentCount = 3;
link.CascadeOrientation = Orientation.Vertical;
nick00
Re: arrange diagram
Reply #2 - Feb 3rd, 2009 at 3:50pm
Actually I am trying to show the nodes in two ways
TableNode View
ElipseNode View
If I use the above code while creating the links
I get the result as shown 1 and 2 image
Image1:
Image2:
but after creating link if i update the control point I got the images 3 and 4- problem with this is my links getting overlapped i want to show each link separatly, yes they can cross but not overlape each other, see image 5 where overlapping effect is clear.
Image 3:
Image 4:
Image 5:
but i believe even i dont want to update the control points i can still get the effect which i am expecting. Is there any way without updating the control points.
nick00
Re: arrange diagram
Reply #3 - Feb 4th, 2009 at 2:22pm
After some calculations on Link.ControlPoint
somehow i got the layout which i want,
Now my consern is if my layout is very huge, in that case I dont know how it will work, is this lowers down the pwrformance.
if yes! then
Is there any other way instead of updating each link's control point.
thanks,
Re: arrange diagram
Reply #4 - Feb 4th, 2009 at 2:42pm
This looks as if it can be implemented to run in linear time on the number of links. If you are using only a single loop over Diagram.Links, there's nothing to worry about Wink
